Efan questions for the 8.1L
Old Apr 9, 2009 | 05:47 PM
  #21
Whippled 496's Avatar
Well, I am just about done with the fab up on these things. I had to make a false back for the Efans that was a little bigger than the stock size. I added some ears to it so it would sit down on the radiator clips. Tomorrow I will build the harness and should have it in on Saturday. Here are a few pics of the setup....
Here is the 05 Efans.
Here is the false back with ears that I made.
This shows how i trimmed the lips off the back of the fans and made them flush for a tight fit on the panel
Here is the back of the panel
Here are the fans sitting on the panel.
I hope it works out...I will let you know on Saturday.
Old Apr 9, 2009 | 05:56 PM
  #22
Mangled03gmc's Avatar
Baltimore Whore
Damn looks really good man, hell ya its gona work out...
Old Apr 9, 2009 | 06:39 PM
  #23
KySilverado's Avatar
Some TRICK work there
Old Apr 9, 2009 | 07:36 PM
  #24
budhayes3's Avatar
PT's Slowest Truck
That looks very cool, I'm sure it'll work great!
Old Apr 12, 2009 | 04:52 PM
  #25
Looks like its gonna work out well. Got them installed and tuned in today. Outside temps were only about 60* so i will need to wait till warmer weather to really test them, but they kept it in the 172-178* range with no problem. I drove it for about 30 minutes to get it up to temp then pulled over and let it sit and idle to see how it would do with that. I let it sit for about 10-12 minutes and it would run up to 178*(low speed turn on temp) and quickly fall back to 172* (low speed turn off temp). It did this several times before I got back in an drove home. I will get some more updates when it gets warmer...but first impression is good!! . I really like the bidi controls in EFILive where i can turn them on and off at the click of the mouse too. Test both speeds and they work nice....they pull a lot harder than i thought they would.
As always....here are some pics of it installed.....
Old Apr 12, 2009 | 09:15 PM
  #26
budhayes3's Avatar
PT's Slowest Truck
Man, that looks way too cool, I'm really impressed by your ride BTW, looks like you're missing a clip in the center of your plastic radiator cover
Old Apr 13, 2009 | 05:33 AM
  #27
LOL....cant get nothing past you guys. Its in the parts tray on the work bench...i will put it back, I was too excited to try it out.
Old Apr 18, 2009 | 07:35 PM
  #28
Just a follow up to the Efan happenings. Today it was about 83* outside and sunny so i figured it was a good time to try out the efans and A/C. To make a long story short they are working beautifully. Drove around for 20 -30 minutes with more than a few WOT runs and the temps never went above 175* with or without the A/C on (i have a 160* T-stat). Parked it and let it idle for 10-12 minutes with the A/C on and it still never went above 175* and the air was ice cold. Next test will be in some 90*+ humid days but i think we are still a month or so away from those.
Old Apr 18, 2009 | 07:40 PM
  #29
budhayes3's Avatar
PT's Slowest Truck
What are your fan on and off temps set at?
Old Apr 18, 2009 | 07:52 PM
  #30
I am running the dual pin set up controlled by the PCM.
