8.1L Whipple 2.9L Supercharger
Old 07-01-2015, 09:05 AM
Raylar Engineering's Avatar
Originally Posted by Whipped383
So we're screwed if we want low 5-6 psi boost then?
You can always order a procharger kit for a 496MAG and adapt it to your motor. That'll give you 3.5-5lbs of boost.
https://www.procharger.com/marine-su...cruiser/efimpi
Old 07-01-2015, 10:43 PM
Whipped383's Avatar
Screw that I'll stick with the Whipple I already have if I decide to do it. Yours is just prettier and intercooled
Old 11-28-2015, 10:05 AM
makes children cry
_zebra's Avatar
underdrive crank pulley?
Old 03-10-2016, 02:35 PM
Its been a long time since our last update, but we picked up a 2003 GMC Yukon 2500 off craigslist with an 8.1L (4x4, 3.73, 4L80E) that had blown its pistons up. After tearing the old 8.1L out, we tossed in one of our new 8.8L / 540cid crate engines with stock iron heads and a 202 cam.
For those wondering, the 202 cam in a 540cid displacement is perfect for stock heads as the cam falls off right about the same time the heads do (4200rpm). In terms of driveability, this combo might as well be a dead stock offering from General Motors. Expect about 440hp / 540ft-lbs.
We decided to make the GMC a test mule for the the 2.9L blower kit which is finally back from the casting company. After driving it around town, all I can say is blower whine is the ultimate mechanical temptation to stand on the throttle.
Here are some shots of the completed kit - we should have dyno numbers in the next week or two for the 540 budget build.
Old 03-10-2016, 08:22 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Certainly looks good!
I couldn't find any of your cam specs listed anywhere.
I have been told you can't really go above .530 lift without replacing the pistons on a factory 8.1L So I would have to assume the 202 does not exceed that?
Old 03-10-2016, 08:34 PM
Thanks!
Yep, you can't go over .530 lift or the valves start kissing the pistons. If you do have aftermarket pistons, you still have to cut down the iron head's valve seats as they have the same limit.
Our 201 Heavy Towing / 202 Towing / 203 Street Strip / 211-S (supercharger) / 212-T (turbocharger) are all safe to run with stock pistons.
Here's the description for a 202 in a stock 496 / 8.1L: High torque camshaft. Stock-like idle. Best for daily towing emissions compliant Truck / RV use under 8000lbs. Safe for stock pistons. Powerband: Idle - 4700rpm
Old 03-10-2016, 08:53 PM
1FastBrick's Avatar
Originally Posted by Raylar Engineering
Thanks!
If you don't want to share your specs that's fine.
What about LSA? I was considering a 114LSA. Stock 8.1L Long block with a Modified intake and a 90MM TB
Thoughts?
Old 03-11-2016, 04:20 PM
Thoughts?
Edit*
114 is about the minimum you'll want to run in terms of LSA. Our towing cams (201/202) are on a 116 to maximize output with the long runner intake and produce the broadest possible torque curve.
Old 03-11-2016, 07:41 PM
1FastBrick's Avatar
Interesting. The one i was looking at was a split duration like 214/220 on a 114
Old 03-15-2016, 05:25 PM
1FastBrick's Avatar
What do you recommend for springs? I was looking on your site and your valvetrain package says to go to comp for springs.
I see an outer spring and a beehive spring?
Is the Beehive for a stock replacement with factory locks and retainers and the outer requires different locks and retainers?
Quick Reply: 8.1L Whipple 2.9L Supercharger
