3/4 ton, front suspension, pitman/idler arm support kits
Old 07-20-2009, 12:45 PM
  #21
TX Tahoe Z71's Avatar
Originally Posted by Kerr
Just wondering why you need that and what it cost or helps do..
Reason i ask is im at 120K miles, and need those i think... the guy at the inspection station said needed two new things somethng arm and rod i think..... I have the leveling kit and 33's on a bead locks..
Answer to the cost of the support kit and name of the arms question:
Originally Posted by subtlez28
Man, $231!? Does it come with both sides (idler and pitman)?
Is this a major problem for non off road trucks?
I'd love to keep my truck's steering feel tighter longer!
The replacement idler and pitman arms both run around $70-80 each. MOOG is a top notch brand for these replacements.
You don't necessarily need them, meaning your truck will drive without them, but it will clean up some of the steering slop (where you can move the steering wheel back and forth a bit without the truck actually changing direction). From what I understand, the Cognito support kit just keeps the idler and pitman arm from wearing out much longer than without the support kit. A Cognito rep told me that the arms should be replaced at about 30k miles if you don't have the support kit.
Old 08-05-2009, 08:46 AM
  #22
no title here
skyhighsami's Avatar
They seem to be what everyone uses on the diesel trucks so they can do a 4wd launch
chopperloco
07-10-2016 10:45 PM
ZONES89RS
21
09-24-2015 05:58 PM
black03rcsb
09-01-2015 10:17 AM
Ketis
07-23-2015 12:37 PM
Quick Reply: 3/4 ton, front suspension, pitman/idler arm support kits
