3/4 ton, front suspension, pitman/idler arm support kits
Old 07-09-2009, 10:13 AM
TX Tahoe Z71's Avatar
Originally Posted by BlownHD
I have the pitman/idler brace from cognito and it works great, I replaced both arms when i did it, and i've already driven twice the distance that I did on the stock setup, with no issues.
Did the brace help tighten up the steering much? I'm not going to be doing much, if any, offroading, but I would like to get rid of a lot of the steering slop.
Old 07-09-2009, 11:14 AM
BlownHD's Avatar
Its going to feel a lot like it did brand new, but it is going to stay that tight a lot longer.
Old 07-09-2009, 11:49 AM
BlownHD's Avatar
Found it, rcv performance is the name of the place with stronger CV axles.
Old 07-09-2009, 06:56 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Matt Im coming down next weekend.
Old 07-10-2009, 12:15 PM
02BlueStepside's Avatar
Plan on doing the cognito supports/braces on my dually as its sloppy right now. Have heard many good things
Old 07-10-2009, 01:46 PM
subtlez28's Avatar
Man, $231!? Does it come with both sides (idler and pitman)?
Is this a major problem for non off road trucks?
I'd love to keep my truck's steering feel tighter longer!
Old 07-14-2009, 11:15 PM
1slow01Z71's Avatar
Thats for both sides, and it doesnt make it feel any tighter it just makes it stay tighter longer. If youve got a decent amount of miles on the truck it would be best to replace both arms then put the braces on. After that, you shouldnt have to replace them again, expecially with just street use.
Old 07-14-2009, 11:38 PM
subtlez28's Avatar
Yeah I read that on their site. So w just 11k miles, if I put them on my steering will be tight forever... right.
Great... another part on my list...
Why can't I leave anything stock...
Old 07-20-2009, 11:40 AM
Kerr's Avatar
Just wondering why you need that and what it cost or helps do..
Reason i ask is im at 120K miles, and need those i think... the guy at the inspection station said needed two new things somethng arm and rod i think..... I have the leveling kit and 33's on a bead locks..
Old 07-20-2009, 12:41 PM
Tootall's Avatar
pitman arm, and a tie rod end . . . that's probably what he said.
Quick Reply: 3/4 ton, front suspension, pitman/idler arm support kits
