05 2500hd motor mount install
Old Jan 28, 2012 | 12:11 PM
TJ's Avatar
TJ
Default 05 2500hd motor mount install
6.0. looks to be pretty straigt forward, not sure if there are any tips to help to keep me from cussing.
Old Jan 28, 2012 | 12:31 PM
moregrip's Avatar
what a rush!
should be an easy task, no surprises. The bolts are long.
Old Jan 29, 2012 | 08:26 PM
TJ's Avatar
TJ
i dont know the proper procedure. i was going to just undo the mount off the motor(4 bolts) and the 3 bolts off of the frame mount. the frame bolts felt like i was going to turn the heads off of them. tight all the way out. damn factory loctite is always stout.
mount wouldnt come out, had to take the frame stand off to get the mount out and reinstall the new one. (2 6" long bolts)
i can see it not being as easy on a 4x4. looking back, i should have taken the splash gaurd out of the fenderwell to make it a lil easier to fish things around in there.
Old Feb 1, 2012 | 09:11 AM
sand man's Avatar
Drop the front diff and lift the motor and then u can remove the mounts easy
another way insted of removing the splash gaurd is remove the exhaust manifold
Old Feb 1, 2012 | 06:36 PM
TJ's Avatar
TJ
ive got a 2wd. i didnt get into lifting the motor, just had a jack under the tranny. i could do it a lil quicker next time. clutch fan going out now. just scored a set of electric fans from the junkyard for 100 bucks. going to put them on this weekend.
BennyB
Aug 1, 2015 08:48 AM
silver-mod-o
Jul 27, 2015 05:24 PM
85SS/85GN
Jul 22, 2015 12:48 PM
oharajo
Jul 18, 2015 09:24 PM
Nimoryan
Jul 5, 2015 03:50 PM
