o2 sensors and exhaust leaks
Old 05-06-2015, 12:31 AM
C450's Avatar
Default o2 sensors and exhaust leaks
How sensitive are o2 sensors? I'm working on a 5.3 with MP turbo. My long term fuel trim on bank 2 reads good. Bank 1 is reading 25. I found an exhaust leak and fixed it but it hasn't changed the ltft readings. Just bank 1 is running super rich. Plugs are fouling out and I keep changing them to make sure I don't have a dead cylinder causing my problem. I've changed out new intake gaskets with another set of new gaskets. I'm convinced I do not have a vacuum leak. Could a pin hole in the exhaust be causing a false reading at my bank 1 o2 sensor? I'm not seeing any holes but I'm about to pull my crossover pipe off again and check it out. Would anything else cause this issue?
Old 06-17-2015, 03:46 PM
shuetuning's Avatar
Exhaust leaks can throw them off pretty bad. Can you put a wideband in to see if it has the same issue? Maybe it is just the sensor itself.
noproblems209
08-10-2015 06:57 PM
05GMC4.8
08-07-2015 09:55 PM
zblee
08-03-2015 03:45 AM
Ketis
07-23-2015 12:37 PM
Mzay
07-06-2015 11:03 PM
Quick Reply: o2 sensors and exhaust leaks
