replaced steering column/ engine won't start?
Old 02-10-2017, 11:50 PM
Wolftrk99's Avatar
Try disconnecting the battery then relearning the passlock... may reset any codes that were stored
Old 02-12-2017, 07:42 AM
Registered User
5starsparklingpools's Avatar
I disconnected the battery and did the turn off and on 3 times and still it will not start
Old 02-12-2017, 09:09 AM
Wolftrk99's Avatar
What vehicle is it, lets back up and start there!
Old 10-28-2017, 10:02 AM
Registered User
Jason291705's Avatar
Default Security Code Reset
The answer for the security code reset works perfect. I have an 06 GMC Sierra Crew Cab with a 4.8 replace the transmission and the steering column truck was cranking fine with the old one put the new one in wasn't cranking read this forum did the security code reset truck runs perfectly. Thanks for the info hope all you Chevy lovers out there are keeping it real!
Old 03-16-2019, 02:16 AM
Registered User
Christopher Patrick's Avatar
Default 04 Silverado will not start after changing the steering column the odometer lights ar
The odometer lights does not work after changing the column and does not start their security light does not work at all
Old 09-26-2023, 11:18 AM
Registered User
unclutchauto's Avatar
Post 2017 chevrolet suburban
Originally Posted by dc_justin
Agree with Grumpy, but it doesn't need to be done at the dealer. Takes about 45 minutes to do it.
Attempt to start, when it fails, leave the key in the run position for 11-12 minutes (til the security light goes off).
Turn off for 30-45 seconds.
Repeat first step.
On the 4th attempt of this process, it should fire up.
Justin
I replaced steering column on 2017 chevy suburban (push start) and car will not start, computer reads wrong pin. what process would you use with remote?
joc
10-13-2012 08:13 PM
5STAR
12-04-2011 06:06 PM
CashDudeHomie
19
08-26-2008 05:06 PM
R0SS
11-15-2007 01:31 AM
shandy294
16
05-23-2007 02:08 PM
Quick Reply: replaced steering column/ engine won't start?
