Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
Go Back   PerformanceTrucks.net Forums > GENERAL MOTORS SPECIFIC FORUMS > Tuning, Diagnostics, Electronics, and Wiring
Sign in using an external account
Register Forgot Password?
Register Albums FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGarageUsed CarsStore TSBs & Recalls
Welcome to PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 05-13-2011, 04:57 PM   #1
Trader Rating: 0
Default Chevy truck fans running after truck is turned off
I have a 2006 chevy Silverado Z71, last week my cooling fans decided to start running after the truck has been turned off. I know they will come on if the motor is overheated even if the truck is off but the truck is never overheated and they never turn off. They will continue to run until the battery is dead.
I have changed the temp sensor and checked all 3 relays and everything looks great. Anyone have some input on what might be going on?
bigbass1307 is offline   Reply With Quote
Old 05-13-2011, 05:31 PM   #2
Trader Rating: 9
Swerve7rpm2000's Avatar
if your fans relays are breaking ground, you can have a split back ground wire touching frame somewhere or motor where it has rubbed and come in contact making ground which in turn will never turn off.....so check all your ground wires in the fan harness and make sure they are not rubbing and coming in contact with metal
__________________
1995 RCSB Chevy 408, 9:1 Cr, Callies Crank/Rods, Diamond Pistons, TFS 225's, Garret 91mm, AMS1000, Alkycontrol, KB Hot Parts, Custom Intercooler & Piping, Ladder Bar, drag springs & QA1's, Full Manual Th400 & T-Brake, Circle D, Full Spool 3.42, Champion Forged Wheels, 5" DP w/ Magnaflow, 10 Point Chromeoly Cage
http://Build Thread: http://performa...d.php?t=469809
Best Passes: http://www.youtube.com/watch?v=s7Uir...ure=plpp_video
Swerve7rpm2000 is offline   Reply With Quote
Old 05-13-2011, 06:25 PM   #3
Trader Rating: 0
I know if the motor is running there are 3 hot contacts and 1 grounded. while the motor isn't running therre are 2 grounds and 2 hot.
Old 05-15-2011, 09:22 AM   #4
Trader Rating: 0
I cleaned the ground connection for the fans and checked the rest of the wires as best as I could and found nothing. Last night it threw a engine misfire detected, knock sensor code, fan relay switch code and was running terrible. I was also getting a blueish white smoke from the exhaust pipe and an occasional backfire. then all of the sudden the codes went away, the smoke diappeared and it started running fine again.
Old 05-15-2011, 11:01 AM   #5
Trader Rating: 1
foose04's Avatar
My truck has a done this a few times, I had to tap the relays a couple times and it turned off.
__________________
2004 GMC RST: TMS Iron 347/S480/4l80E
Old best 4.8L/S475: 919HP/880TQ
Quickest/Fastest 4.8L Truck 10.17@134.26 (retired)
91 Eagle Talon: AWD/2.0L/Turbo/E85-10.77@136, 570AWHP Mustang Dyno (retired)
http://www.youtube.com/watch?v=yB9kDxXRLgw
foose04 is offline   Reply With Quote
Old 05-15-2011, 03:44 PM   #6
Trader Rating: 0
I have changed the knock sensors, changed sparkplugs, changed relays, I am still getting a misfire code and a fan circuit relay control error code. I am completely lost at this point. I am looking at buying a pcm from a 2wd Avalanche 2006 model. Does anyone know if these two pcms are interchangeable?
Old 05-15-2011, 05:21 PM   #7
Trader Rating: 2
08k1500_3's Avatar
Sounds like you have a wire harness that is chafing somewhere and shorting the fan control circuts which will cause the fans to stay on all of the time, also in the same harness the coil, injector, and knock sensors are all in the same harness and if shorted to ground will cause all of the codes that you are setting!!! Sounds to me like it is time to start checking wiring!!!!
__________________
2008 NNBS 4wd RCSB 5.3/Patriot stage II 243's/TSP 224r cam/DOD delete/Calspeed 1 7/8" LT's ORY/Nelson tuned/Zex 125 shot/Powertrax Quik-loc/Circle-D 3200/Caltracs/3-4 drop
422rwhp/458tq before heads... Sold
New DD 2012 ECSB 5.3/6L80E.. Stock...
Drive Fast, Take Chances!
ASE Master/L1 Certified GM Technician
08k1500_3 is offline   Reply With Quote
Old 05-15-2011, 06:22 PM   #8
Trader Rating: 8
Quote:
The PCM is interchangeable but it will not start you truck until programmed.
__________________
2005 RCSB 5.7 LS1 386 RWHP/371 RWTQ 11/12/12
2004 Avalanche LS1 308 RWHP
2003 Suburban 5.4 330CI 10:5.1 Compression 291 RWHP
TXSZ66AVLANCHE is offline   Reply With Quote
Old 05-15-2011, 07:03 PM   #9
Trader Rating: 0
Quote:
That's the thing, its not always running, when I start the truck they turn off unless I turn the ac on. then they will turn back on after the truck is off. If it was a grounded wire I thought they would run all the time regardless if the switch is on or not.
Old 05-17-2011, 01:27 PM   #10
Trader Rating: 0
about 8 pins on the end of the blue connector were corroded. Got some contact cleaner from radio shack and gently cleaned it with a wire brush, seems to be running fine now and the fans have turned off. I'm still getting a little smoke from the exhaust, probably because I gutted the cats yesterday, but I'm going to run some berryman's through it and see if that helps.
PerformanceTrucks
Ford F150
Paid Advertisement
Tags
2006, avalanche, chevy, continue, continues, coolant, fan, gmc, off, run, running, sierra, switch, trailblazer, truck, turn, turned
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
