TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Traction bars?
Old 12-07-2015, 09:39 PM
nitrousaddict's Avatar
Default Traction bars?
I'm considering getting traction bars on my RCSB lowered silverado. will these make a huge difference? is it worth the price on a daily driver? I dont know a lot about them and they sound like a great way to get a stiff start.
Old 12-07-2015, 11:41 PM
FFDP's Avatar
Do you have major traction issues??
You'll also want to look into the tires you are running aswell if you do.
Old 12-08-2015, 12:04 AM
GMCtrk's Avatar
I wouldn't run them on a true DD.
Old 12-08-2015, 06:28 AM
Occasionally I'll fishtail off the line or if there's uneven surfaces in the road while turning the rear will act like it is. I just replaced my tires all around with V rated 275/55/20s, so there's probably not a huge problem there.
Old 05-22-2016, 01:24 AM
Registered User
Othelious's Avatar
Personally, I am seeing some spring flex on mine at mid 400's hp, and going to put some caltrac's on mine. you would just have to make sure that you have the clearance still for something like that, or even traction bars with you being lowered.
Old 05-22-2016, 12:04 PM
10 Second Truck Club
RS/SS 4.8's Avatar
Traction bars either assasn bars or caltracs will stiffen the hell out of the rear suspension. There will be almost no suspension travel out back hence the coment about not using them on a true dd. I have some on mine and only use the at the track. On the street i have them back out pretty far so they arent making contact at all.
Old 05-22-2016, 12:07 PM
RS/SS 4.8's Avatar
Also street tires are useless under power. Look into a tire like the ET street S/S. My truck on a 4/7 drop has no axle wrap even on drag radials without the assasins hooked up.
Jake Herring
12-08-2015 01:42 PM
bigsapper
11-20-2015 05:36 PM
carid
11-20-2015 08:18 AM
Budakane
11-12-2015 10:16 AM
Quick Reply: Traction bars?
