E85 flex fuel injectors!
I found this info on these injectors
Fuel Injector Specificatons:
Length: 2.6 in/65 mm
Oring to oring: 2.0 in/52 mm
Diameter: 0.65 in/16 mm
Oring diameter: Viton, 14 mm
Injector type: Saturated
Coil Resistance: 12.5 OHMS
Flow rate: 380cc/min at 3 BAR/36lbs/hr at 43.5 PSI
Latency (dead time): 0.500 ms at 14 volts
