2004 5.3 intake,pan,acc,+
This is all off an 04 5.3 with around 14,000 miles.
All prices INCLUDE shipping.
DBW-Engine wiring harness/auto- $50
Cooling Fan- $10
Oil dipstick/tube- $10
All for $55
I want this stuff gone by the 5th or I'm cutting up the harness for the plugs I can use and throwing the fan and dipstick away.
PM me your email if you want pics.
Cooling Fan- $10
All for $55
Originally Posted by '89ChevyMadneSS
harness uncut?
have any bracketry?
how good of a deal for all accessories and harness?
have any bracketry?
A/C pump is gone.
Updated list with some brackets I found.
should this harness work with most sensors on an 01 motor?, the motor i have is just the long block, so i need the intake fuel rails and inj.s etc.etc.etc. but im just curious if that engine harness should work on my 01?
That I do not know. I know the injector plugs on this harness look different than what I'm used to. But everything else looks the same. So you only have a couple sensors on the motor? I guess if you can find out if those sensors will swap. Then you should be able to use it.
Just let me know.
Edit:
Did some research. This harness will work for you but you will need a drive by wire throttle body setup. Because that is what this harness is for. If your wanting to do drive by cable. It will not work.
Hope that helps.
Just let me know.
Edit:
Hope that helps.
