please help!!!!!
Old Mar 19, 2009 | 10:28 PM
  #21
mcfarlnd's Avatar
Un-Registered User
could it be a flat spot in the cam???
Old Mar 19, 2009 | 10:56 PM
  #22
Originally Posted by 4.8T
on my honda that had a spun rod bearing i could pull the plug wire to the cyl and the nock would go away. it doesn't go away when i do it on the truck.
Yea, piston slap noise will remain with the cylinder shorted unfortunately
Old Mar 20, 2009 | 06:13 AM
  #23
TURBHOE's Avatar
so did i just wear out the skirt in my hard driving that day? i think this weekend i will drop the pan and check bearings. can i see the skirt at full drop on the crank for that piston?
Old Mar 20, 2009 | 06:35 AM
  #24
white lightning SS's Avatar
You wont be able to see the skirt, you will be able to see any abnormal wear on the thrust surfaces on the cylinder walls. Cheapest way to go is get a low mileage used LQ4 put ARP rod bolts in, transfer your cam, heads, and new lifters and let her rip. Your gonna spend at least 1500 plus for forged pistons, new bearings, and machine work. Plus the down time. You can get a used motor for that.
Old Mar 20, 2009 | 07:36 AM
  #25
TURBHOE's Avatar
one small problem. my new heads on a lq4 would be like 10:1+ scr which would suck for boost lol. other than that i agree. i'll do some searching and see what i can find. this blows!!!!!!
Old Mar 20, 2009 | 09:24 PM
  #26
TURBHOE's Avatar
well, i put a bench press bar on the side of the motor and tap tap tapity. put the bar on the valve cover and head and nothing at all really quiet. put it back on the block and there it is. i put it on toward the back and its quiet...er but the front two are loud. so can i put some 10w30 and a bottle of lucas oil in there to get by for awhile?
Old Mar 20, 2009 | 09:35 PM
  #27
I bet that it could make that noise for a while and not give you any problems but noise. I've had vehicles where piston slap is characteristic due to the wrist pin design. The ZZx crate motor knocked like crazy for over 80k that I owned it and never missed a beat. You could try a sligtly thicker weight oil, but I doubt it would make a difference, but maybe a 10w-30 is worth a shot.
Old Mar 20, 2009 | 09:56 PM
  #28
TURBHOE's Avatar
hell, i need to change the oil anyway from the head swap. i still wonder if it was caused by the hard driving i did the day it started. my guess is the piston just swoll up enough (during long boost period) to wear a little and now it clacks around.
Old Mar 20, 2009 | 10:39 PM
  #29
That sounds like it could be the cause...quick question, is the noise louder when it's cold?
Old Mar 21, 2009 | 09:05 AM
  #30
TURBHOE's Avatar
when you first start it its loud as ****. then it quiets down after a few minutes. that's when its hard to hear, until you put a load on the motor
