Color Matched front end?????
Old 02-23-2016, 09:57 AM
CF7GO's Avatar
Default Color Matched front end?????
What are you guys using to get the paint to stick to your chrome front ends?
I have the front bumper wrapped with vinyl but I want to get it painted.
Old 02-23-2016, 01:05 PM
abey15's Avatar
The bumper needs to be sand blasted before painting.
As far as the rings around the headlights, scuff then really good with some scotch brite.
Old 02-23-2016, 07:29 PM
mikeyjm1's Avatar
What else have people used? what chemicals, primers, paint? It just seems paint will chip easily and show the chrome.
Old 02-23-2016, 10:52 PM
abey15's Avatar
There isn't much you can do with the headlight rings, except make the surface good and rough to give the paint something to stick to. Blasting the bumper will make it plenty rough for paint to stick great. You could also use adhesion promoter to get the paint to stick a tiny bit better?
Even the factory painted front ends chip like hell. If u want to keep it looking good, add a 3m clear bra over it. Seems to work really well!
Old 02-24-2016, 05:38 AM
06 4.8's Avatar
The shop that painted all of my plastics used an etching primer
Old 02-24-2016, 07:29 AM
CF7GO's Avatar
I posted about this on pt.net facebook page since this site doesn't get much action anymore. There was a good amount of info posted there.
I was lucky with my bumper because I was able to pressure wash all of the chrome off.
From what I see, people use a an adhesion promoter, sandable primer, primer sealer, base, and then clear. Some have even had good results with Duplicolor rattle cans....
Old 03-17-2016, 06:52 AM
jakenm's Avatar
If money is not a problem let a reputable shop do the prep and paint work. In this way you can be sure of the outcome and exact color.
Old 03-17-2016, 10:40 AM
slo04's Avatar
painting a chrome bumper is pretty hard, you'll need to really rough up all the chrome if not remove it all, then sand smooth the metal then use an etching primer sand some more then primer then paint then clear.
Old 03-17-2016, 11:41 AM
Phillip123's Avatar
Chrome bumper painting is really a work for a prominent shop to do.
Old 03-17-2016, 01:34 PM
CF7GO's Avatar
As stated above....I was able to get all of the chrome off with a pressure washer.....
Quick Reply: Color Matched front end?????
