obs 14 bolt semi-float swap
Old 07-05-2011, 08:26 PM
chevyrace47's Avatar
Default obs 14 bolt semi-float swap
i finally got some work done on the 14 bolt and figured i'd post pics of what i have so far.
it took almost 4 hours and 4 different drill attachments to get to this
the brake brackets i got from fastbrick and had a friend weld
these are what i used to get it close to bare metal
brake hardware
POR 15 is on the way, then modify the brake lines. get a conversion u-joint for now and bolt it in.
Old 07-06-2011, 11:26 AM
11 Second Truck Club
fastrt's Avatar
looking good so far.
Old 07-06-2011, 11:34 AM
I have a gauge for that
Atomic's Avatar
How far from the end of the axle tube are the flanges welded?
Old 07-07-2011, 12:09 AM
didnt measure from the axle tube since its not exactly square. 1fastbrick told me it was supposed to be 2 5/8ths from the outside of the axle flange. but to be honest i just mocked all the brake components up and tacked it in place. i measured it afterwards and its pretty damn close to 2 and 5/8ths.
Old 07-07-2011, 08:34 AM
JoeyGC5's Avatar
I as well as Atomic and some others know how much of a pain this swap is. Looking good though. Are you going to trim the old backing plate flange off?
Old 07-08-2011, 03:28 PM
Not planning on it. I'm to lazy.
Old 07-09-2011, 12:05 AM
pewterliftedz's Avatar
iv been reading some of the threads and just thought about it. if i find a 68" axle with my same gear set, i could just weld on some spring perches and bolt it up right?
the mods that you and atomic are doing are simply if you WANT to run disks right?
my NNBS already has drums in the rear.
Old 07-09-2011, 10:04 AM
Yes. That would work. But if you could find one from the same body style you wouldn't have to worry about the spring perches. You'll also have to use either a conversion u-joint or change the yoke on your driveshaft.
Old 07-12-2011, 06:49 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Wasn't it 2 and 7/8 from Wheel mounting surface of axle flange to face of backing plate bracket??? As long as you mocked it up properly should be ok.
Old 07-12-2011, 07:12 PM
yeah, thats right. i was just trying to remember what it was when i wrote that. did you use an obs rear end when you did your swap?
Quick Reply: obs 14 bolt semi-float swap
