How to set a FPSS without a FP Gauge?
Old 07-02-2014, 01:07 AM
redram2007's Avatar
After looking at the jetting charts for Chrysler I noticed it is set for 45-54 FFP. The earlier 4.7 runs at 49 psi and my 07 is 58 psi. Is this much change worth considering changing the jetting at all? Sorry for all of the questions, just trying to understand everything and make sure I get it right the first time or at least as close as possible.
Old 07-02-2014, 09:04 AM
banker099's Avatar
The Proton jetting is based at 50psi, so it may be a little bit rich but it should be fine. jetting charts for 50spi vs 58 psi use the same jets for most of the jet settings.
Old 07-02-2014, 11:18 AM
redram2007's Avatar
Right on!!! Thank you.
Old 07-02-2014, 11:39 AM
redram2007's Avatar
What about nozzle placement? My CAI tube is almost s shaped and doesn't have much room to get a straight shot to the TB unless its installed close to the TB. Mostly everything I have seen or read, people are putting them very close to the TB. But I read an article earlier and Ryan Lewis said this:
Single nozzle systems also give a great deal of flexibility in installation – basically, the nozzle can go anywhere in the intake tract before it splits into the individual runners for each cylinder, though Lewis advises that there are a few good rules of thumb to follow. “The further away you can get it from the intake valve, the better the atomization process,” he explains. “18-24 inches away from the throttle body will be your best-performing placement.” That distance allows for the nitrous oxide and fuel to thoroughly mingle with each other, and the incoming atmosphere. Better distribution between cylinders, and an increased charge-cooling effect are the results.
Old 07-03-2014, 08:51 AM
Former Vendor
Nitrous Express's Avatar
That's all true, i might have a biased opinion though
Old 07-03-2014, 08:55 AM
redram2007's Avatar
I somehow didn't realize that was you lol.
If I mount it further back from the TB it's not going to be less effective since its not a straight shot into the TB?
Old 07-10-2014, 01:02 AM
redram2007's Avatar
What size fuse is recommended for the bottle heater and the solenoids?
Old 07-10-2014, 08:41 AM
Former Vendor
No, it will follow the same path as the air that travels through there.
40amp fuse in line with each.
Old 07-10-2014, 11:20 AM
redram2007's Avatar
The only problem is I can't find any 40 amp rated inline fuse holders locally that isn't designed for car audio that uses 4 to 8 ga wire. I have several 30 amp fuse holders and they have 12 ga wire. Will a 30 amp fuse work or is it safe to put a 40 amp fuse in the 30 amp holder?
Old 07-11-2014, 08:43 AM
Former Vendor
If the wire is shorter than 10ft you should be ok with a 12ga wire and a 40 amp fuse.
Quick Reply: How to set a FPSS without a FP Gauge?
