Will This turn my 40s
Old 01-10-2017, 09:35 AM
Registered User
Ole_Red_LQ4's Avatar
Default Will This turn my 40s
Hi guys I have a 2000 2500, sitting on 15" lift and some 40x13.50s
I've recently pulled my lq4 6.0 with 300,000 miles and have done a complete rebuild,
Bored block .030 over
6.125 compstar forged rods
-5.00 CC flat top pistons
New bearings all around
Set of 317 cast heads ported and polished and milled down for higher combustion
BTR stage 3 truck cam
Beehive valve springs
Comp cams 1.8 rocker arms
Log tube headers
3" borlas stainless exhaust from headers back to a set of borlas XR1 competition mufflers
Can yall think of anything else I might be missing? This motor will be receiving a pro charger down the road.
Old 01-10-2017, 11:12 AM
ltr450ryder's Avatar
Tbss intake and 90mm throttle body would add a nice touch to it as well.
Old 01-10-2017, 02:18 PM
Ken in AZ's Avatar
Gears 4.88's would benefit you greatly off the line.
I run 3.73's with my 40's but that's on my 650hp Powerstroke - it does keep the revs down on the freeway for fuel economy and the 1200wtq doesn't have any trouble pulling itself or my 10k lb towhauler so I don't plan to change them.
I do have 3.73's on my 37's on the chevy and the difference between that and 5.13's are considerable. Probably 2-3mpg less on hwy difference but the off the line performance is where it's at. Trade that any day, so much more fun.
Old 01-10-2017, 04:16 PM
Registered User
Thanks guys I forgot to mention I have the tbss intake and 90mm throttle body,
Also have 4.11 gears in My 14 bolt with Yukon mechanical lockers
Old 01-11-2017, 02:12 PM
Mconcha's Avatar
4.88 gears minimum.. 5.13's would make you feel like you spent your money right on that engine.
Old 01-11-2017, 08:26 PM
GREENSIERRA's Avatar
what diffs do you have?
if you can run 5.38s that would be even better.
I ran 5.13s and 5.38s with 40"s and the more gear the better.
Old 01-17-2017, 04:19 PM
PowellSixO's Avatar
The more gear the better without a doubt. I run 4.88's on 35" tires, and I regret every singe day that I didn't go to 5.13's. I let the shop talk me out of it at the last minute. To get that big thing moving, you might even consider a 2800ish stall torque converter.
Old 01-17-2017, 04:41 PM
PowellSixO's Avatar
Out of curiosity, how far did you mill your 317's? And what push rod length did you come up with when putting the motor back together? I ask, because I just sent a set of 317's off to have them milled .035". I know I won't have the same CR or efficiency of a set of 243's, but they're pretty much free heads with very very low miles on them, I have a set of PAC springs for them, the machine work is also free, so I said what the hell.
Old 01-17-2017, 05:19 PM
TXsilverado's Avatar
I agree with everyone about gears... don't fear the gear. your drivetrain will thank you. some members will run a 4.56 on a 30" tire.
Old 01-19-2017, 08:40 AM
Registered User
I milled .030 and when my machinist gets done with them I'll let you know what push rod length and are you running stock length connecting rods ? And stock pistons?
