LQ9 Build Advice
LQ9 Build Advice
Ok so after going back and forth on what I'm going to do engine wise I think I've finally figured out what direction I'm going to go. My truck is a 2000 Chevy Silverado 2500 with the 6.0 after a little bit of research I realized this particular engine wasn't the best choice for a build. So anyways after talking myself out of a turbo build(atleast for now). Well anyways now to the details...
So I decided I was going kinda mild since this is my first ls engine build. My current engine is tired so I started looking for a replacement engine and came across a low mileage LQ9 locally and decided I wanted to go that route. I haven't purchased the engine yet but I decided on a mild 400 rwhp goal for the LQ9. I want to keep it naturally aspirated and daily driver friendly because I like driving my truck and want it to keep its street manners. I have a decent idea on what I need to get there just looking for a little insight from y'all.
Ok, so current list
-LQ9 Engine
-Cam (specd out by tuner)
-Good Set of Heads
-Springs
-Valves
-Pushrods
-Lifters
-Comp Trunion Kit
-Oil Pump
-Timing Chain
-Long Tube Headers with Offroad Y Pipe
-Full Exhaust
-FAST Intake
-Injectors
-Fuel Pump
-Tuning
-Stall Converter
Let me know if y'all have any suggestions I already have a built 4L80E so I'm not worried about the transmission. Any advice is always appreciated. Thanks.
Ok, so current list
-LQ9 Engine
-Good Set of Heads
-Springs
-Valves
-Pushrods
-Lifters
-Comp Trunion Kit
-Oil Pump
-Timing Chain
-Full Exhaust
-FAST Intake
-Injectors
-Fuel Pump
-Tuning
-Stall Converter
Yes I was planning on using the stock LQ9 heads I was just going to give them a port and polish and all new insides. Do you think this goal of 400 rwhp is achievable?
Agree with everything except the converter then cam selection, figure out your cam and then your stall off of that..if it ends up being a higher atall than you want then yiu can adjust everything..... As far as injectors you will probably be ok with the 07+ flex fuel injectors that would come with the intake... I have a complete intake off of an 11 5.3 flex fuel if you decide to go that route...
