Double roller timing chain oil pump drive?
Guys I've search all over and I can't find the oil pump drive spacer that goes on the crank thr drive the oil pump. I found a double roller chain set with it in the kit but I only need the drive. Hope someone know a place to buy just the drive spacer. Just so everyone know what I talking about is the single timing chain the oil pump drive is part of the lower gear on the double roller setup it separate.
mhorn0817
11-06-2016 12:14 PM
