quick question about TB....
Old 01-07-2008, 05:12 PM
navy_ao_05's Avatar
Default quick question about TB....
i have a 2001 4.8(drive by wire) but the motor i got today is a 2004 6.0 and it has a electroic tb. what do i need to do to convert dbw to the electronic tb or vise versa.
Thanks Robert
Old 01-07-2008, 05:17 PM
High on diesel fumes
thunder550's Avatar
Just reuse your original intake manifold and throttle body. It will be much easier that way. The manifolds are essentially identical except for the throttle cable bracketry, and the throttle bodies themselves are the same size.
FYI, you have a cable throttle body, not drive-by-wire. DBW is the same as electronic.
Old 01-07-2008, 08:11 PM
navy_ao_05's Avatar
oh ok thank you for your help
Old 01-07-2008, 08:59 PM
Stoichiometric's Avatar
DBW is possible on traction control equipt trucks. They are rare but some are floating around out there.
Old 01-07-2008, 10:24 PM
thunder550's Avatar
No problem
Justin87gn
09-10-2015 12:06 PM
custm2500
09-08-2015 05:53 PM
bisqikss
09-08-2015 03:35 AM
SWINGRRRR
09-03-2015 07:49 PM
mr03silverado
09-02-2015 11:43 PM
Quick Reply: quick question about TB....
