Stock driveshaft
Old 11-10-2016, 10:14 AM
Hunt&Fisherator
silver-mod-o's Avatar
Default Stock driveshaft
About to regear the truck finally...
With a 4.10, when is everyone having problems with the stock aluminum shafts? If it's over 100 I'm not concerned with it but I don't want to have to pucker every time I pass someone.
Old 11-11-2016, 07:23 AM
shaw_426hemi's Avatar
I have 4.10s wuth a 6 speed crew cab 4x4 I've been up to 110 many times.
Old 11-12-2016, 05:35 PM
Hunt&Fisherator
Mines a 4spd crew with the longer aluminum shaft... Thus the reason for my concern.
Old 11-13-2016, 12:43 PM
Jason Z69's Avatar
I had to upgrade mint to a 2pc. It started the death wobble at 78mph but balanced back out around 85 to 90mph. It had 33in tires at that time
Old 11-14-2016, 11:31 AM
iamkeniff's Avatar
I ran 4:11s on my stock one with 275/55/20s for a long time. Then finally upgraded to a gmt800 2 peice for about 100-200 total i think.
Very simple to setup
Old 11-15-2016, 04:22 AM
Jake75's Avatar
mine wobbled around 60 mph. Had to get a 2 piece and it fixed
Old 11-17-2016, 12:31 PM
Hunt&Fisherator
Was the ECSB steel 2pc shaft pretty much a drop in deal minus putting in a x member for the carrier?
Old 11-18-2016, 08:09 PM
iamkeniff's Avatar
Yes sir, very simple. I set my front shaft to the trans, then just set the rear 2 u-joints vs trying to dial in all 3 u-joints.
You can either make a bracket to come off the center support (i did that) or make a full crossmember all the way across the frame like the oem brackets.
Spicer makes a 3r to 1350 u-joint now, vs the junk conversion joints at the part store.
Old 11-22-2016, 11:41 AM
What is the length on a CCSB driveshaft? A buddy of mine has a 2500 900 series suburban and that has a 1 piece steel driveshaft and itlooks like those can be ordered online for $250-350. Not sure what the length would work on, i saw it said 68 1/4"
Old 11-24-2016, 05:44 PM
iamkeniff's Avatar
My custom 2 peice was over 80" if i recall
