service stabilitrak/service traction control, why does this keep coming on?
mine does that every time i drive it...it was so bad that it would throw me into limp mode if i got on the throttle from a stop and would not reset if i just restarted the engine...had to pull neg battery cable to reset...anyway we actually narrowed it down to ecm...changed it and the stabil trac/traction control message still comes on but it doesnt throw me into limp mode anymore...
b2sdad (04-16-2021)
i read that, and started laughing. then i realized you weren't kidding. there is such a thing as a "SWPS".
ZR1 forum thread about code C0710
i'll have to check the connector for corrosion, and see if it stops doing it.
I am having the same issue with my '07 Tahoe LT 5.3L. Message Center cycles: Service Stabilitrak, Service Traction Control, then it goes to Engine Power is Reduced and rides like a farm tractor. Happened on Friday 12/7. Parked it for a few hours then drove it home about 15 miles. Drove fine today, but last night went bonkers again. I took it to the dealer today and they said I need a new throttle body. Got 98,000 miles on the clock, never had a problem before. I will change out the thottle body and an evap solenoid that's been bad for awhile and report back. They said I have 5 codes at the dealer. I changed the battery over the w/e and installed a new air filter, both of which were overdue.
Seen the TB cause it a number of times. Its a problem with the TPS in the early throttle bodies(07-08). Pt#12580760 if memory serves me but GM recently released a TPS service and replacement kit too (haven't memorized that # yet).
