08 Denali, fuel line rust?
Old 09-01-2016, 07:58 PM
tgui's Avatar
Default 08 Denali, fuel line rust?
The drivers side lines near the cross member. The lowest one on the frame near the ground in the plastic holder has a good amount of rust.
Can I splice in a length of good fuel line in the manner I've made brake lines in the past using the flare tool? Would there be too much pressure and seal issues?
Any better ways to fix it?
Old 09-01-2016, 11:32 PM
Wolftrk99's Avatar
Best bet would be to replace it if its that bad... Could repair it, but its not as easy to find the proper size line for fuel lines as it is for brake line.
Old 09-02-2016, 08:14 AM
tgui's Avatar
Those kits are $$ and then I'd have to drop the fuel tank. It looks like I *could* get away with a 5 inch straight piece of tubing.
3/8'' OD tubing right? I found some copper-nickel tubing on Ebay.
What fittings can handle the pressure?
Old 12-27-2016, 05:43 AM
95wannabe's Avatar
What did you end up doing?
I have the same issue in 2 different spots about a foot apart
TVS/HC
05-03-2016 10:41 PM
Mark Johnson
19
04-19-2016 12:59 PM
regency
04-18-2016 09:57 AM
GM1697
04-05-2016 10:17 PM
FarmTruc
01-08-2005 08:44 PM
Quick Reply: 08 Denali, fuel line rust?
