2001 5.3 into a 2005 suburban
Old 09-18-2014, 09:04 PM
MAXJEEP's Avatar
Default 2001 5.3 into a 2005 suburban
I have a 5.3 on a stand that is stamped A171 by the water pump. From what I have read this is January 17 2001 engine. Is this correct? I have checked and it is a 5.3 I have the chance to buy a 2005 Suburban that needs an engine. Can anyone tell me if my 5.3 will work? The local junk yard said the interchange number is different. Thanks for any help
Old 09-18-2014, 09:06 PM
FFDP's Avatar
It will work. The block anyway, some top end stuff on the suburban is different.
It should have a returnless fuel system I think and throttle body is drive by wire. But nothing that will matter too much.
Old 09-18-2014, 09:09 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Yes, The basic long block will work.
Some of the sensors changed as well as the throttle body, intake manifold, Exhaust manifolds and so on.
Old 09-19-2014, 04:49 AM
MAXJEEP's Avatar
So will the long block work. I just have to swap all the bolt on stuff. Is the cam sensor in the same place? I thought I read it has the sensor up front like an ls2
Old 09-20-2014, 10:46 PM
MAXJEEP's Avatar
Anywone?
Old 09-20-2014, 10:50 PM
FFDP's Avatar
Still in the same spot.
SLOPONY
20
10-18-2016 06:05 AM
slowmo934
09-09-2015 12:24 PM
rojeho
08-08-2015 07:20 PM
05GMC4.8
08-07-2015 09:55 PM
Quick Reply: 2001 5.3 into a 2005 suburban
