Tighten up my steering
Old Sep 13, 2011 | 02:02 PM
firebladeJJ's Avatar
Default Tighten up my steering
I wanna tighten up my steering on my '04 Sierra RCSB to much like my '99 T/A.
I've searched for some threads on this but doesnt seem to be really any conversation on the matter. Any ideas? Is as simple at a rack and pinion swap from a f-body? or is there kits out there?
Thanks.
Old Dec 6, 2011 | 10:29 AM
Bumping this back up, I cant really find any info on the matter. Is it not adviseable to do such a swap or impossible(from a budget point of view).
Old Dec 6, 2011 | 10:54 AM
Slammed96's Avatar
Is the truck already rack and pinion? I would imagine there should be performance racks out there for these trucks.
Old Dec 6, 2011 | 04:20 PM
yeah my truck already has a rack and pinion setup on it. I just havent found any info or seen anyone do a swap for a truck.
Old Apr 18, 2012 | 02:22 PM
bumping up for anyone with information that might help.
Old Apr 18, 2012 | 08:23 PM
SnakeOiler's Avatar
Are you looking for a quicker steering ratio? If so, yeah, that would be a nice change. Feels like I turn this thing forever.
Old Apr 19, 2012 | 07:58 AM
yeah, a quicker ratio would be awesome. I cant really find anyone that has done such a swap or any info. From what research I have done, it looks like I might be able to get an f-body rack, fab up some stuff and it will work, but, this could be a disaster waiting to happen. I'm gonna try anyways.
Old Apr 20, 2012 | 02:00 PM
After spending some time last night looking on the internets I ran across some data on steering ratios. What I found is: the Trans AM with the WS6 package has a steering ratio of 14.4 where as my truck has a ratio of 14.2 I dont get it, if the truck as a better ratio then why does it not turn as well? Is it just the size of the steering wheel that is the difference?
Old Jun 2, 2012 | 02:29 AM
Rudy91040's Avatar
May or may not help, but I believe that make steering quickeners, not sure if that is the correct term, that will speed up or slow down your steering depending on how they are installed. They go in line with the column.
Old Jun 3, 2012 | 07:29 PM
oldred95's Avatar
The lower the number numerically the more movement you get at the tires with less movement of the steering wheel.
If you want to yours feel like it has quick ratio steering go drive Chevy Equinox in the 05-08 range. Those things take almost 3 3/4 turns lock to lock. Jump in one of those and try to pull into a parking hole after driving any other vehicle and you will nearly wipe out the car parked next to you.
What about the Silverado SS? For some reason I think its going to be the reciprocating ball type steering box instead of rack and pinion.
Also alignment specs can make your truck drive like less of a truck and more of a performance truck. The more caster you have the more return to center and the better it will hold a straight line. Think how squirrely a shopping cart is vs a really raked out chopper. A little negative camber will also make it have a little less understeer.
simman22
Jan 21, 2017 10:27 PM
dsbodley
Nov 14, 2015 09:46 PM
Blklgt
Sep 28, 2015 03:21 PM
vipergtrdj
Sep 16, 2015 07:06 PM
George C....
Sep 11, 2015 04:45 PM
