Stock air box VS cold air intake
Old 11-28-2010, 10:17 PM
  #21
terravast4's Avatar
Originally Posted by Jermoslin
Post pics of modify factory air box!
Just cut a lage hole in the bottom so it sucks fresh air from fender area..you can even run some flex tube to the fog lamp area for a ram air effect.
Old 11-28-2010, 11:13 PM
  #22
Bumpers's Avatar
Originally Posted by grey matter 04
like needs a retune bad since i swapped intakes
Hopefully with a retune i will see some gains
But as of now running on my old tune it slowed down 4mph and 4tenths
I'm sure its all jacked up because its bringin in a lot more air than it thinks.. With a retune it should make a big difference I would think
Old 11-28-2010, 11:27 PM
  #23
13 Second Truck Club
grey matter 04's Avatar
man i hope so if not that was $450 wasted!!!
Old 11-28-2010, 11:31 PM
  #24
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I would just go with a smooth tube from the tb to the stock box and hack the box behind the headlight.. Or buy a volante kit if you can find one cheap
Hey Ive got one of those for sale in the classifieds right now for 150, thats pretty cheap IMO.
Old 11-28-2010, 11:32 PM
  #25
Bama2door's Avatar
Where can you just get the tube going from tb to filter? Is there any gain making it out of 4" tube?
Old 11-28-2010, 11:40 PM
  #26
Bumpers's Avatar
It has to pick up some.. I've got the intake and everything I just need to buy some 42lb'rs and the harness and I will be ready to roll ..
Old 11-29-2010, 01:51 PM
  #27
heres how i cut my air box
Old 11-29-2010, 04:06 PM
  #28
11 Second Club
rel3rd's Avatar
Thumbs up
Here's how I did mine. Cut it as much as possible. I also cut the steel bracing underneath, as much as I could without affecting it's strength, anyway. I use a Fram AirHog air filter and an Airaid intake tube. Works great as per my datalogs.
As you can see in Pic#1, I can turn the angle of the horn, then I beep the horn for an extra 2rwhp, LMAO!
Attached Thumbnails Stock air box VS cold air intake-airbox-modded-1.jpg   Stock air box VS cold air intake-airbox-modded-2.jpg
Old 11-29-2010, 04:23 PM
  #29
1slow01Z71's Avatar
I wish I could do that, Id be afraid of getting my filter wet in the mud/streams out on some of the land I drive on.
Old 11-29-2010, 04:50 PM
  #30
11 Second Hall Moniter
AKlowriderZ71's Avatar
This is how I did mine.
Quick Reply: Stock air box VS cold air intake
