Stock air box VS cold air intake
#21
#22
I'm sure its all jacked up because its bringin in a lot more air than it thinks.. With a retune it should make a big difference I would think
#24
#26
#28
Here's how I did mine. Cut it as much as possible. I also cut the steel bracing underneath, as much as I could without affecting it's strength, anyway. I use a Fram AirHog air filter and an Airaid intake tube. Works great as per my datalogs.
As you can see in Pic#1, I can turn the angle of the horn, then I beep the horn for an extra 2rwhp, LMAO!
#30
needs a retune bad since i swapped intakes
