any difference in 4.8l heads and 5.3L heads?
Old 08-19-2004, 09:25 PM
LARRY01Z28's Avatar
Default any difference in 4.8l heads and 5.3L heads?
title says it all guys. is there any difference in the 4.8L heads compared to the 5.3L heads. thnaks alot. larry
Old 08-19-2004, 09:38 PM
the compression ratio would be different because of the difference in bore size 4.8 should raise compression slightly on a 5.3
Old 08-19-2004, 09:41 PM
LARRY01Z28's Avatar
ok, so i could put 4.8 L heads on my camaro (2001) and they would be better then the 5.3 L heads?
are the vlaves and stuff like that the same?
Old 08-19-2004, 09:50 PM
Dark Halo's Avatar
The 4.8 and 5.3 have the same compression, the only difference in the 2 motors is the rod length and the crank stroke.
HomerSimpson (11-17-2021)
Old 08-19-2004, 09:52 PM
LARRY01Z28's Avatar
ok, thats all i wanted to know man. thanks a millon.
Old 08-19-2004, 09:55 PM
Dark Halo's Avatar
No prob, you can get either head and it will be the same.
Old 08-20-2004, 05:37 AM
02Reaper's Avatar
I think the 4.8's and 5.3's have a different casting number. Some of you guys with a 4.8, look at the casting numbers and see if they are #706. I have a 5.3 and mine are #862. The last set of #706's I had, 4.8 was stamped on the bottom where the lifters go.
Old 08-20-2004, 08:02 AM
LARRY01Z28's Avatar
ok, thanks alot for the info guys.
Old 08-21-2004, 11:13 AM
and the 5.3s have dished pistons.
as for the heads, the numbers on my '02 4.8 yesterday were 862, and they were stamped 4.8. however the numbers on my buddy's '01 4.8 we pulled 2 weeks ago were 706. did the numbers change for the model year or something?
5.3lSilverado
25
08-29-2016 12:48 AM
lxcoupe
07-27-2015 08:19 PM
projectnightcrawler
07-19-2015 11:30 PM
jmarkway
07-18-2015 09:23 PM
FlowmasterMufflers
07-17-2015 03:26 PM
Quick Reply: any difference in 4.8l heads and 5.3L heads?
