LQ4 swap in 07 silvy, suggestions?...
I have a 07 silverado with a 5.3 that just recently started leaking oil everywhere. Appears to be a rear main seal. So I figure, great excuse to put a bigger motor in.
Donor motor is '04 LQ4 from a van. Motor is bone stock but I want to install a good torquey cam for pulling the race car trailer. Not worried about upper rpm horse, just low rpm highway cruising with trailer behind. The 5.3 has the DOD and if it's possible I would keep that. I plan on just pulling the intake from the flex fuel 5.3 and reinstall on the 6.0. The truck has the stock 4L60e and not planning on changing that out but recommendations to help it last longer would be appreciated.
So basically, I need the following-
-cam recommendations
-mail order tuner that can make all this work
-low cost headers that will fit
- would like to keep everything else stock.
NNBS trucks are 2007.5-2013. They have GEN 4 motors which, depending on the motor, have DOD. If you have an nnbs you won't be able to use a gen 3 motor without a lot of work. The knock sensors and reluctor wheels are different.
You best bet is to sell that motor and find an LY6 that will drop right in.
GrooveCityZ71
08-31-2015 12:05 PM
