Injectors for TBSS intake swap
Curious what injectors everyone is using on their TBSS intake swaps? I do have cam, intake, and exhaust. My 03 Silverado SS will be down a couple weeks as a tranny gets built for me by FLT so I figured now is a good time to go ahead and do the swap as well as send the PCM off for tuning. I want injectors that will fit the TBSS intake and fuel rail without spacers or anything and be able to tune for easily. I am willing to buy adapter pigtails if need be.
Porksoda I don't want to high jack your thread but I have the same question. My truck is a 2004 rcsb has a 6.0 swap, stock bottom, 243 heads with a mild P&P, 228r cam, CAI, long tubes, efans, 3000 stall, all the normal stuff. I am swaping my stock intake to the nnbs intake, its from a 2008 Silverado 5.3, already has rails and injectors. I know my old injectors will fit in the new rails, but do the nnbs injectors flow more #s. Is it worth it to run the nnbs injectors or run the old ones? My truck is already tuned for the current setup, I know I will need a retune after intake swap. Just want to know if the new injectors are any better.
Soooo
6.0 with 243s 228r cam all boltons.
NNBS intake swap injector choice.
Run stock old injectors?
Use the NNBS injectors?
What adapter harness will work?
Will I be safe to drive with the swap until the retune?
Soooo
I ended up going with the non marine 8.1 injectors. Hopefully they are easy to tune. Anyone know if the hardware from the truck intake will work on the TBSS or do I need to buy TBSS hardware? Intake bolts, fuel rail bolts, and throttle body bolts.
The fuel rail bolts and intake bolts are the same. The TBSS intake is a 4 bolt so you will need an adapter if you are using a 3 bolt throttle body. Fast makes one for around $40. You will need to use the fuel rail from the tbss which is a nicer piece anyways.
GrooveCityZ71
08-31-2015 12:05 PM
maxspeed05V
07-19-2015 07:08 PM
