Do I need larger injectors?
I have a 5.7 ls1 with 243 heads and a custom cam. Cam is low duration, specd for truck use. Im using my stock 2003 4.8 truck intake/exhaust/tb/maf/injectors.
I think my stock injectors are 26#. With the stock intake and exhaust, I expect to make around 330-350whp through the auto. Stock converter and limiter.
Will these 26# injectors support my fueling needs?
Slowest turbo build ever!
Ideally yea no more than 90% but I have no issues. Im also right around 330hp now with a good tune, LTs and ory.
And I could be wrong about what size my stock injectors are. If mine are the 24-26# injectors then you might want to look into some in the 30something range.
rednekferlife101
09-14-2015 05:27 PM
