Mounted my Tru Cool 40k transmision cooler a little different.
Old 07-25-2009, 12:39 AM
11.0 Moderator
SUX2BU's Avatar
Default Mounted my Tru Cool 40k transmision cooler a little different.
So i finally got around to installing my 40,000 GVW Tru Cool transmission cooler. I put it after my radiator because this is such an efficient cooler that if mounted up front like most people do my tranny would run at about 150* and that's a little too cool for me. Plus mounting it after everything i'll get better A/C performance and my motor will run quite a bit cooler, since i by passed the stock radiator in tank transmission cooler and removed the front auxiliary cooler.
Tranny temps before were about 200* and coolant was about 189* with about 103* ambient temps in stop and go driving.
After temps with about 102* ambient temp stop and go driving were about tranny 180* and coolant 177*.
Stock auxiliary cooler
Tru-Cool 40,000 GVW cooler.
Old 07-25-2009, 12:55 AM
Black'Rado's Avatar
were does your fans go? or am i missing somethin?
Old 07-25-2009, 01:22 AM
006rcsb's Avatar
x2
i didnt know tranny temps could be too cool
Old 07-25-2009, 01:39 AM
Wearin' da big hat
00ChevyScott's Avatar
150 degree tranny temps are perfectly fine. I'm sorry but this cooler setup is ******* retarded. You should've gotten a smaller cooler if you were that worried about it.
Old 07-25-2009, 01:44 AM
11.0 Moderator
SUX2BU's Avatar
That pic was during the install. Fans go on just like normal. You have almost 3" between your radiator and fans.
Old 07-25-2009, 02:00 AM
11.0 Moderator
SUX2BU's Avatar
How is it retarded? I put i the cooler last since it's highly efficient so as to free up the cooler air for the the other coolers. The way i see it my set up has my temps all running pretty cool in a tank with a 3200 stall.
Well i also put it there cause i need the room upfront for this.
Old 07-25-2009, 02:21 AM
I have a gauge for that
Atomic's Avatar
So you spent 100 bucks for a 10 degree difference and your happy about that? I am missing something....
Old 07-25-2009, 02:27 AM
11.0 Moderator
SUX2BU's Avatar
10 degree?
Whoops, fixed my post it was more like 20* drop in tranny temps.
I had to ditch the front mount tranny cooler so i got a huge one, ran it after all the other coolers and still dropped 20 degrees, coolant temps went down quite a bit too. All will come into play very well after this up coming week.
Old 07-25-2009, 02:31 AM
TXsilverado's Avatar
tell us what you really think
Old 07-25-2009, 09:58 AM
616 of 933's Avatar
what does it matter where he puts it its his truck. looks good. can you show the fans installed
Quick Reply: Mounted my Tru Cool 40k transmision cooler a little different.
