04 rearend?
Old 01-21-2010, 05:43 PM
da_vato's Avatar
Default 04 rearend?
what rearend is in an 04 crewcab, 5.3, 4l60e
Old 01-21-2010, 08:22 PM
da_vato's Avatar
bump...... anyone??? Ive searched all over the site
Old 01-21-2010, 10:20 PM
leonpiper69's Avatar
just the plain old newer style 8.5 i thought. same rear from late 80's to present, unless its the HD like 1 ton etc. i could be wrong but im pretty sure they are all the same.
i grabbed a ;ocker out of the junk yard ot of like an 89 truck to put in my 99 gmc sierra. i was told the only differance between the older and newer is the spline count. and of course the width might diff between some housings (like from blazer to k series etc).
Old 01-21-2010, 10:22 PM
Wearin' da big hat
00ChevyScott's Avatar
It's a 30 spline 8.625" 10 bolt. Same ring gear size as older 8.5" rear ends, but the spline count is indeed different and the bearings are different as well.
Old 01-22-2010, 08:56 PM
da_vato's Avatar
thanks just what I needed, just ordered a the true trac.......... I appreciate it 00ChevyScott
Old 01-23-2010, 02:59 AM
Restricted User
bohr898's Avatar
leon piper is fukd....the 99+ 10 bolts get bigger carrier bearings... unless you have a 88-98 box body......i understand that the box body ran into 99 also.......they all share the same size ring gear tho
Old 01-23-2010, 03:00 AM
Restricted User
bohr898's Avatar
they share the same spline count too
97_ek
09-23-2015 09:16 PM
600 horses
09-10-2015 11:01 AM
03chevytruck
08-25-2015 09:08 PM
BlackDog
27
06-04-2004 09:57 AM
Quick Reply: 04 rearend?
