Classic Crew Cab 2wd leaf spring making a "w"....
I was under the truck yesterday changing oil and power steering fluid and went to take off my oil filter and noticed that the leaf springs on my crew cab were making a "w" shaped like it had a load in the bed of the truck when the truck bed was completely empty. The only mod is 2" drop shackles, the pinion spacer removed to correct the pinion angle, and bilstein shocks.
Any one notice this with their 2004-2007 Classic crew cab? I'm just wondering if I have a bad batch or whether after 63k miles that the leaf springs are just weak and need to be replaced. I've always found it odd that my reg. cab OBS truck can with three leaf springs plus an overload and my heavier crew cab came with two plus an overload. Can someone look under their crew cab with no axle flips and see what their springs are doing?
Thanks!
Thanks!
Hunt&Fisherator
Springs are broken. I've had a set reworked that did this and turned them into lift springs but for the most part your just stuck buying new springs. My 2000 ext cab did the same thing. Keeping an eye on my GMT900 crew to see if the same thing happens. All I've done is removed the rear lift blocks and reshim the pinion. I tow a 20ft car hauler occasionally but nothing super heavy. My tractor is not real big either, just a 30hp with a 5ft brush hog and front end loader... So far, I've got 60K on this truck and it's showing no signs of damage.
