internal and external pumps FOR BOOST
Is anybody running an internal and external pump .I WAS thinking about trying to put external pump along with my aero 340 .drilling a hole at back of my tank near rear end .And run an external pump and y it in to my feed line .and put a boost sensor and a relay to turn it on .i think the hardest part is go to fitting that want leak .any thoughts
11 Second Truck Club
i did this same thing. I drilled a hole in the rear of the tank, ran a line up to my "custom" fuel rail crossover. I cut an inlet off another fuel rail and welded it into the stock crossover. Second pump runs off a hobbs switch and stock regulator works fine. Fuel pressure is consistent and rises 1:1 with boost. Works great! Been that way for 3 or 4 years now.
Drilled a hole in the rear. The pump only runs when I'm above 5psi, and the back of the tank is where all the fuel will always be at that point. I could take a pic sometime if you want. Think I tapped the hole for 3/4 pipe and used some epoxy also. Never leaked or had any issues.
