Ford Engine & Exhaust Performance All EFI, 4.6, 5.4 Triton
Supercharging a 4.6
Old 08-19-2010, 09:52 PM
turboescalade's Avatar
Default Supercharging a 4.6
I was just wondering if anyone had experience in supercharging a 4.6L in a 2000 Ford F-150, I seen that Kenne Belle makes one for the mustang, I have an aftermarket hood so clearance is definitely not an issue. Any help would be muchly appreciated.
Old 08-27-2010, 12:31 AM
I paid my buck-o-five
stoffer's Avatar
how skilled are you???
Kennebell used to offer a kit for your truck and it sucked, (no i/c and high charge temps)
allen engineering offered an M90 kit
procharger
paxton
vortech
powerdyne
etc used to offer kits and several still do, do you want a centrufigal or a positive displacement??
if you want a positive displacement the tork tech kit with the '03-'04 cobra eaton M112 will be your best option
Old 04-10-2011, 06:46 AM
Grant218's Avatar
i was curious to wondering if the tork tech kits work on the 4.6's
Old 04-16-2011, 05:25 PM
Faster150's Avatar
they might but the mustangs and trucks use a different timing cover so some of the brackets might not bolt up the same
Old 08-04-2011, 02:55 PM
topgun10x's Avatar
i have a 1998 f-150 with the 4.6 stroked it out to a 5.0 and have a pro charger on it at 12 lbs. it is at 320 at the wheeles and still working on getting it tunned right for the 3rd time.
Old 08-04-2011, 09:00 PM
blackcash's Avatar
Blown stroker only making 320 at the wheels? That's gotta suck
Old 08-04-2011, 09:33 PM
13 Second Truck Club
A Low Dime's Avatar
Stroker motor should be making 320 on motor.....not to mention adding 12lbs to it, should be making 500
Old 08-05-2011, 06:57 PM
topgun10x's Avatar
it was built by Shawn Hiland out of Canada. he said it would make 350 on the engine alone and would handel 16 lbs. of boost and rev to 7000 rpm. i havent seen any of those yet.
Old 08-05-2011, 08:03 PM
11 sec. Truck Mod
TIM Z's Avatar
Man im not tryin to be an *** but for 2 grand or less you could have 400+ horse cammed 6.0 .
Im sure you have at least 5Gs in your engine alone?
It sure is expensive to make power with a ford.
Sucks your not having good luck with your build so far, hope it turns around!
Old 08-06-2011, 05:39 AM
topgun10x's Avatar
thanks Tim, i beleive it more like $7000.00 is what we spent. i had the cash in hand to have it redune again from a different place but do to bills it had to go there insteed. maybe one day.......... oh and forgot to mention that i am still running stock compresion at 9 to 1
Quick Reply: Supercharging a 4.6
