Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
h/c/I 4.8 guesstimate, then b00st
Old 08-12-2014, 09:33 PM
lukn4trbl355's Avatar
Default h/c/I 4.8 guesstimate, then b00st
Tomarrow the truck is getting a base map and within the next few weeks will be getting dyno tuned. Just figured I'd see what you guys were thinking hp wise. It's a low mile 4.8 short, block lt's ory single 3.5" Exhaust Tbss intake 228r cam on a 112 lsa, tfs 205 cnc ported heads at 10:1 4k converter through a fully built sonnax trans. Will be adding either a d1 or maggie come winter. Just figured I'd see your guesses since I'm clueless on what it'll be making n/a and on a little bit of boost
Old 08-13-2014, 10:48 AM
Slowest turbo build ever!
black00chev's Avatar
If this is all going through the 35's, I wouldn't expect to see over 330hp at the tires. But thats just my guess though. What kind of times are you running with that setup?
Old 08-14-2014, 09:37 AM
I havnt tested the new setup at the track previous cam only on 35s went 14.3 spinning if i could drop one tenth in my 60 I probably would've had a 13sec pass.
AdaMax
05-16-2016 11:35 PM
legerwn
56
11-15-2015 10:21 PM
Slammed silverado
09-28-2015 06:14 PM
97_ek
09-23-2015 09:16 PM
vipergtrdj
09-11-2015 05:52 PM
Quick Reply: h/c/I 4.8 guesstimate, then b00st
