Cam and no converter..
Alright, so here's the deal. Talking to Martin over at Tick now, he's figured out a cam for my build. It will be going into my turbo build, but plan on putting it into my N/A motor for now just to run around with some lope and more power! I'm not sure on how big it'll be, no lift or duration numbers or anything, just wanna learn more about this: Is it aboslutely necessary to run a higher stall with a cam, or is it just a racing thing? That's a lot more money to throw at the build right now that I wasn't looking forward to, haha. It's my daily driver and sees a lot of stop and go, and from what I understand the 4L80 has a higher stall already, so what's y'all's input?
What are the specs on your truck. Is it your 2001 2500? Im guessing 6.0 with it being hd and 4l80.Makes a difference if its a single cab or 4 door. And 2wd or 4wd. And gear and tire size.
Yeah it's the big rig. 2001 Sierra 2500 HD, four wheel drive, LQ4, 4L80, 3.73 gears with "35" inch Toyo's, really measure out to be 33's. I plan on going to 4.56's soon though. Crew cab. Weighed in at 6,800 on the scrapyard scales.
Truck Sponsor
It is not necessary to have a converter with a cam, but it does require certain specs. If you go too big with it on the stock converter you will encounter driveability problems.
Thanks for the help man, I may swing this over into LS1Tech and see what they have to say. Little more active over there. No body likes playing in trucks
