intro to 600 yards
#22
Top rifle is a American Precision Arms 6.5-284 set up for F Class
1000yd taper F Class, Broughton 5c barrel
Remington action
Jewell trigger
fluted bolt
Badger ordance rings and bases
Mcmillan A5 fully adj
USO 3.8-22x58mm
Smallest group was 2" at 600 yards shooting off a harris bi pod
Shooting 142gr SMK at 3000fps
Remington action
Jewell trigger
fluted bolt
USO 3.8-22x58mm
#23
Bottom rifle is my baby 7mm-300wsm APA
Lawton single shot m7000 BR action
Broughton 1000 F Class taper
Fat Bastard Brake
Jewell trigger
Mcmillan Baker special stock
Lawton 20moa base and Badger rings
DD Ross bolt handle
S&B 5-25x56 PM2
Smallest group was .416 at 356 yards and I was rining the schatt out of a 14" plate at 960 yards.
It shoots a 180gr Berger VLD at 2950
Fat Bastard Brake
Jewell trigger
DD Ross bolt handle
S&B 5-25x56 PM2
#25
Well didn't go to bad. My 300 yard zero was a little off got it sighted in and hit a few x rings. 600 yards and wind was a different story. Was about a half a min short on elevation and couldn't get steady enough. But managed a few 9 and 10 rings but no x. To much heart beat thru the scope plus trying to hold over the same amount every time. Also the 168 match bullets were shooting lower by bout 2 inches at 100. Seemed to be a hotter load tho gun heated up in about 4 or 5 rounds. All in all a fun morning tho.
#26
Now you get to learn your breathing technique to slow your heart down. Also ive found out if you cross your right leg at a 90* and rest your right ankle over your left knee it takes some of the pressure off your chest so your heart isnt making you bounce around.
And remember use your bone structure as much as you can, your muscles are never going to be your best bet when trying to keep still.
#27
#28
Most basic breathing technique ever but it works for me. Two long slow deep breaths, then a third but only let it half out. Focus. Shoot. And as mentioned above, never rely on muscles.
#30
What brand of scope are you running? I only ask because you shouldn't be running out of adjustment at 600. Also there are plenty of 20MOA bases that will allow you to shoot to the magical 1k if you so desire one day.
