WEAPONS What? Trucks and weapons don't go together?
Factory Rem 700 at 600yds.
Old Apr 30, 2010 | 10:01 AM
  #31
nonnieselman's Avatar
Originally Posted by 05_GMC
My dad has a 300wm with a few mods: extended barrel thats been fluted, thumb whole stock with merc bars, gets the rounds loaded by a friend. We've blew some coyote in half at close to a 1000 yards lol. Was made for long range shots at them rocking chair bucks.
Extended?
Old Apr 30, 2010 | 10:54 AM
  #32
KySilverado's Avatar
That is true, i used the Hornady lock n load OAL
http://www.midwayusa.com/viewProduct...tnumber=570611
It lets you check the depth and go from there.
If you seat them too far out and your bolt wont close..... Eh, well dont force it. if you do we might not be seeing you around.
Sorry Noonnie, didn't mean to butt in with the depth thing. After going back and re-reading you did mention keeping it off the lands.
I'll share my method for checking and setting bullet depth. Old school and I've used it for years and has worked well with no cost for a gauge.
Resize a case. No powder or primer and just barely seat the bullet. NO CRIMP. Apply lipstick to the bullet end and chamber it in the rifle. This will allow the chamber of the rifle to seat the bullet to the length of touching the lands. Verified by the rifle land impressions on the bullet and in the lipstick. Measure COL and do this 4 to 5 times to verify its coming up the same. Subtract whatever amount you want it off the lands from this and should be a good COL for just off the lands. Load a few more dummies up like this and lipstick them, chamber and verify its not touching the lands via the lipstick read again. Only good for this lot of bullets and different for every type bullet you'd use.
Old Apr 30, 2010 | 12:29 PM
  #33
Its all good..
I like the Hornady Locknload gauge. Its simple and only takes 5 seconds to check..
Then set the die up for a few thousandths longer to seat them with and go back and set it up for the right length..
I actually seat my bullets to touch the riflings then make them .05" longer. No pressure signs yet with 59grs of H4831SC and a BR2 primer.
The velocity is alot more consistent.
Old Apr 30, 2010 | 08:51 PM
  #34
Mud slinger's Avatar
I have heard of this method before, but with a sharpie. I was going to try it but a black sharpie doesn't show up to good on winchester balistic silvertip bullets, because there black. Might try the lipstick though.
Old May 3, 2010 | 09:00 AM
  #35
i use to use a shapie,, that took way too long..
Old May 3, 2010 | 09:17 AM
  #36
Daryn's Avatar
Formerly darynC-10/23/10
these last couple weeks. me and my instructor has been talking about sizing and customizing bullets/ cases to fit different chambers ... and we are talking about tolerances down to .0005 - .001 u can be amazed how much that can throw off a bullet. im talking shooting exactly the same hole at well over 300 yds
im thinking about building a custom caliber rifle ... which means casting my own bullets, machining my own cases, chamber, barrel... everything pretty much..
Old May 3, 2010 | 10:26 AM
  #37
And a $200 tax stamp for being a Destructive device?
Old May 3, 2010 | 10:42 AM
  #38
Daryn's Avatar
no one needs to now what the F i keep in my house. if they want to see it badly , they can eye down the big end of my barrel
i need to start lookin for a few ruger 22lr's and a ruger 223 . when the **** hits the fan im goin to be ready..... ive already started digging a moat /w a draw bridge around my place...... JOKIN!!! .... but seriously ,
Old May 3, 2010 | 10:43 AM
  #39
.8 is a bigg ole hunk of lead.
Old May 3, 2010 | 02:53 PM
  #40
jared91's Avatar
i think i trump all. 18 inch group of five out of ten at..... get ready for this... 2000 yds.
cheytac .408 single shot, with the help of a kestral weather device thingie and balistics computer. 419 grain copper nickle bullet traveling around 2750fps, 82 degrees and 86% humidity. that humidity was a bitch makes everything hazy. key here is control your heart rate and breathing. have to tone everything out and just focus on controlling those two things. uncle is ex sniper instructor. he has lots and lots of goodies
