ZL1 Colorado
Old Nov 21, 2012 | 07:03 PM
  #111
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by smokeshow
GDS dealership reflash to a CTS-V operating system and it won't start. VIN matched, VATS removed...no crank. I did notice the ECM/PCM segments are different between the Colorado and CTS-V stuff...could that be the issue with the GDS reflash?
What all did they flash??? just an engine calibration???
Old Nov 22, 2012 | 12:40 AM
  #112
smokeshow's Avatar
Mod with training wheels
Joseph, they did a full GDS reflash. The CTS-V flash didn't work because the ECM wasn't communicating with the BCM with that file on it. Flashed it back to the stock Colorado file using their same equipment and the throttle issue was gone. Kudos to John @ Speartech for that one! Now with the reflash, it doesn't make as much boost. Something with the MAP sensor was messed up too. It makes 14.5psi at the bottom of the gear and around 13 at the top. It will be going to the dyno this weekend some time so I can get it dialed in better. I'll be throwing in some 100 octane towards the end to see what she'll do
Any guesses? 6.2L with the TVS1900 at 13-14psi. 91 octane and then 100 octane, 3000 feet above sea level, Mustang eddy current dyno.
Old Nov 22, 2012 | 01:11 AM
  #113
AKlowriderZ71's Avatar
11 Second Hall Moniter
Well that's good news! I knew the boost didn't sound right, but that was a tricky one.
Old Nov 22, 2012 | 01:24 AM
  #114
lowered907's Avatar
Take video
Old Nov 22, 2012 | 02:19 AM
  #115
Chevy_King1500's Avatar
580RWHP/600TQ
Old Nov 22, 2012 | 02:21 AM
  #116
Spoolin's Avatar
GFYS and STFU
What about the fuel pressure issues? That also related?
Old Nov 22, 2012 | 10:46 AM
  #117
9 Second Club
I just tuned a 2005 colorado e40/t42 with a ls1 with a whipple in it. Ran into several of the same problems you are having. Most were issues caused by the harness being done wrong. Had weird fuel problems also but was an easy fix. What year is the colorado?
Old Nov 22, 2012 | 01:06 PM
  #118
smokeshow's Avatar
I got lucky, the harness was done correctly. It is a 2012 Colorado. I'll get some videos on the dyno and the street.
Old Nov 22, 2012 | 01:40 PM
  #119
1FastBrick's Avatar
Nice!!! Thanks for the update. Sounds like the file was corrupted at some point.
When you started messing with it did it have a ZL1 factory tune or a Colorado tune that was modified to work for this engine package??? Was some one in there jacking with it before you started???
Glad you got it resolved.
Old Nov 22, 2012 | 04:32 PM
  #120
smokeshow's Avatar
Nobody had done any tuning when I first got it. I received the GMPP LSA computer from GM and the stock 5.3 Colorado. It was probably jacked with though...ECMs don't just go bad. ...or do they?
