ZL1 Colorado
Old Nov 20, 2012 | 01:17 PM
  #101
Atomic's Avatar
I have a gauge for that
Old Nov 20, 2012 | 02:00 PM
  #102
ak2007r6's Avatar
Lol..
Old Nov 20, 2012 | 02:01 PM
  #103
smokeshow's Avatar
Mod with training wheels
Originally Posted by Area47
there is a difference between can't and won't. same thing with the ecm flash.
Oh I know lol. They are bringing it to another dealership to get them to try...we'll see how it goes.
Originally Posted by Atomic
I have considered this lol. If the customer would stop going full retard, I would yank that **** out of there and put the power adder on the stock engine. Hell, it has 3 MAP sensors, 2 of which are used (from what I can tell) only for making sure the air filter isn't plugged up. Way too complicated...too much room for error.
Old Nov 20, 2012 | 02:09 PM
  #104
wkdivr's Avatar
I'm going to take a wild stab, that the BCM is somehow messing with the PCM, like not working together, somehow. I know guys have taken these crate engines and put them in older muscle cars without too much trouble. Just a thought, although an interesting project.
Old Nov 20, 2012 | 06:31 PM
  #105
BCM has no influence on pcm driveability functions. It needs to be left with someone who has time to really start tinkering with it to figure it out. This is going to be one of those projects that you simply can't charge for all the time you spend on it shes going to be a lot of off the clock cause I want to figure it out time. I hate these the most but love em when I finally figure them out.
Old Nov 20, 2012 | 06:49 PM
  #106
KOEO fuel pressure should be 55-76lbs
If it hasn't been done I would put a LSA fuel pump in it and flash the fuel pump control module for a LSA camaro. Flashing the FPCM may or may not do a damm thing but there are engine specific calibrations for fuel pump operation under varying conditions that can be causing the problem.
Or scrap the FPCM and go to a boost referenced dual fuel pump aftermarket setup.
Old Nov 20, 2012 | 06:52 PM
  #107
smokeshow's Avatar
I can relate to that. Definitely a love/hate sort of project. I am willing to tinker, but there's only so much I can do with the tools that I have. The truck is being sent to another dealership that supposedly has the ability to perform a GDS reflash of the ECM, so I am hoping that will give us a good response.
I guess the only things changed in the wiring to accept the new engine were the two additional MAP sensors, switching from 5 pin to 3 pin cam sensor, and other provisions for the bypass valve solenoid control. Aside from those things, it should operate exactly like stock. Its just so hard to imagine what might be causing problems when literally everything has checked out good so far.
Old Nov 21, 2012 | 01:52 AM
  #108
smokeshow's Avatar
Here's a video of the throttle going full retard. You'll notice with the key on, the throttle is relaxed at 31%. As soon as the pedal is touched, it snaps back closed to 16% and then proceeds to follow what the pedal tells it to do. After letting off of the throttle, it stays at 16% for a little while and then goes back to 31%.
Old Nov 21, 2012 | 01:46 PM
  #109
smokeshow's Avatar
GDS dealership reflash to a CTS-V operating system and it won't start. VIN matched, VATS removed...no crank. I did notice the ECM/PCM segments are different between the Colorado and CTS-V stuff...could that be the issue with the GDS reflash?
Old Nov 21, 2012 | 03:14 PM
  #110
carbongmc's Avatar
hey, as long as the logs look good...
