x link my only choice? Tbss throttle body/intake manifold swap onto 04 silverado
I am doing the tbss intake manifold and throttle body swap on my 04 silverado.
Is the $200 x link my only choice? Is there any way around it? I've been reading everything I can find, and it appears that may be the case. But I figured I'd double check before spending money that may not be needed.
Lots of us have been down this road before. I think you can swap the pedal TAC module, and wiring from a Camaro to make it work. You can convert to a cable driven throttle body, but that will require more parts, and changing the tune. When it is all said and done I still believe the X link is the easiest and cheapest way around it. The person that makes them is on this site quite often, and very helpful. I have never seen him not chime in on problem that might have to do with an X link. And after all that, I really don't remember any actual problems with an X link.
just get the xlink, makes it a super easy swap and like mentioned, if a problem occurs he is more then willing to help out.
I am local to him and he went above and beyond to help with little problems I was having
FlowmasterMufflers
Jul 17, 2015 03:26 PM
GreyChevy
Jul 7, 2015 08:57 PM
