WOT only shows 98% tps?
Old Jul 15, 2008 | 12:04 PM
Holty's Avatar
Notorious BIG
Default WOT only shows 98% tps?
I havn't done a whole lot of tuning this year as my truck is running pretty well, but i noticed that my hpt scanner is only reading 98% tps when i'm at wot. This never happened until recently. Any ideas what could be wrong?
Old Jul 15, 2008 | 12:12 PM
Wilde Racing's Avatar
How do I change this text
normal
Old Jul 15, 2008 | 12:13 PM
Holty's Avatar
Notorious BIG
Originally Posted by Wilde Racing
normal
even though in the past it had always showed to be 100% tps?
Old Jul 15, 2008 | 12:23 PM
yea, I can't remember the exact theroy behind it, (reason for my short answer, lol) but I have seen it before with drive by wire set-ups....
Old Jul 15, 2008 | 12:49 PM
Holty's Avatar
Notorious BIG
ok, fair enough. But, let me ask you this,.....does that tps % directly correlate with tps voltage? For example, if my n20 controller was set to turn on at X voltage (100% tps) does that mean that it is now only seeing Y voltage (98% tps) therefore not activating my n20 noids?
Old Jul 15, 2008 | 05:18 PM
Grumpy5.3's Avatar
yes it does directly correlate to a voltage. Your TPS nitrous switch should not be set to turn noids on at exactly 100% throttle/X voltage reading.IMHO
Should not be hard to check though, hook a meter to B+ or ground at your noids(which ever one you apply) and have a buddy press the go pedal to see if you are getting B+ or your ground
RustyD
May 23, 2016 07:04 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
carid
Oct 1, 2015 09:22 AM
