won't idle, cam position sensor?
Old Aug 3, 2006 | 10:41 PM
  #31
shandy294's Avatar
Try posting it in the Tuning and Diagnostics section also.
Old Aug 7, 2006 | 08:22 PM
  #32
Well just pulled everything apart and the timing marks seem to line up and the cam is in there snug and isn't loose. So any suggestions before I put it all back together again?
Old Aug 11, 2006 | 05:03 PM
  #33
Got'er runnin again and no change so I did some searchin and people suggested upping the throttle stop screw and if that don't work, the blade screw is pretty much flush on the bottom going up. I drilled the blade and I stopped at 13/64 and its still hit and miss. The colder it is the better it will hold an idle. Should I keep drilling?
Old Aug 11, 2006 | 06:09 PM
  #34
litreddevil's Avatar
Banned
llllllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllllllllllllll lllll
Old Aug 11, 2006 | 06:22 PM
  #35
Originally Posted by litreddevil
is the pcm tuned for the bigger injectors if not that is what it will do i went through this with the 31/lbs
Any help on what to do to tune the injectors and where to get the info?
Old Aug 12, 2006 | 12:37 AM
  #36
you have to turn how much the injectors are told to flow, if you have 28lb/hr injectors flowing at 98% and you install bigger injectors, they will be told to flow at 98% when maybe they should only be flowing at 87% or something. any custom tune should be able to take care of this. HPT, LS1 edit, EFI live etc
Old Aug 12, 2006 | 12:47 AM
  #37
I have a flow calculator all I need is to find out what my origional fuel pressure is what the new pressure is ( i'm assuming the same as I never changed?) and enter the lb rating of the new injector (31) and it'll give me the new flow rate. Just waitin on the new laptop to download the newest version as I am still runnin the 1.6 with a 25 foot cable on the home comp. Just tryin to find out what I need to do then to git-r-dun.
Old Sep 7, 2006 | 08:29 PM
  #38
Well changed the camshaft position sensor and it's still throwin that code, now what?
Old Sep 7, 2006 | 08:51 PM
  #39
v8
17,16,15,14,13,12,11 Drvr
did you line the dots up? I know greggo had the same problem a few years ago. good luck.
Old Sep 7, 2006 | 10:23 PM
  #40
Yeah I thought of that too, so I tore it all apart and had a mechanic friend come over and double check and it was right.
