Wire diagram or schematics please!
Old Mar 4, 2011 | 06:07 PM
cueball's Avatar
Default Wire diagram or schematics please!
I need a schematic of the evap vent solenoid circuit for a 2003 chevy burb 1500 z71
It started doing the P0449 code so I took it off and hooked it up to a 12 v source and it worked fine and it's clean, I can blow through it and when energized it closes fine.
So I put a volt meter on the connector and turned the key on and 4 volts only.
I tried several grounds and a 12 volt source and found it is the 12 volt side that is bad, the ground from the PCM is fine.
So I need a schematic to find where the 12 volt source is and replace that wire.
Thanks!
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
