What's this code mean?
Old Jun 5, 2006 | 08:44 PM
12sec.5.3's Avatar
Default What's this code mean?
P0327 Knock Sensor circuit low frequency EPA
P0332 Knock Sensor circuit low frequency EPA
P0327 " " " EPA pending
P0327 " " " MH
P0332 " " " MH
Does this mean my knock sensors are bad?
Old Jun 5, 2006 | 09:01 PM
RoninsDenali's Avatar
I'd check the weatherpack connector for the knock sensors. Its attached on the top of the intake, drivers side towards the rear.
Old Jun 6, 2006 | 12:28 AM
1slowsilverado's Avatar
I would test the knock sensor... The knock sensor learns min and max frequency's and reports as a/c voltage to the vcm. If the frequency is out of range it will through a Knock Sensor code.
Clear the code and see if it comes back.
If code returns test the resistance from the k/s signal wire to battery ground. Should be 90ish to 105-110 kohms. If not in spec most of the time its a open or short to ground in the harness. (signal wire)
To test the actual knock sensor itsself. Set the volt meter to a/c current and hook up to signal wire and ground near sensor to engine block. Tap the block with a hammer close to the knock sensor. DO NOT hit anything plastic or the sensor If there is no current its the sensor. If there is current its open or shorted to the vcm or bad vcm. But I dought that...
Good luck
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
