Whats the cheapest way to tune a turbo silverado?
Old 12-02-2009, 08:25 AM
Registered User
Breth's Avatar
Default Whats the cheapest way to tune a turbo silverado?
Hey!
Sadly i have no experience with siverado tuning.
I wanna get a turbo on my 2002 5.3 vortec.
I dont wanna spend 1000`s of dollars.
I have a few ideas but i dont know if sombody got experience with this..
I wanna run 8-9psi of boost
-Preador tuner (stock on the sts kits), ist that enougth? I heard that its not real good...
-FMU (in corky bell`s book i have he told thats good till 9-10psi) will that work? Will it work when i would set the ignition a bit back?
-AEM FIC-8 A piggy pack for OBD 2 with full adjustable fuel and ignition, also got a boost-pick-up.
Can somebody help me?
Old 12-02-2009, 08:26 AM
Resident Retard
BlackGMC's Avatar
Custom tune from one of our sponsers, Wheatley or DC_Justin (Blackbearperformance). They run about 250-350ish...
Old 12-02-2009, 08:31 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
Seeing how you are in Switzerland I'd suggest purchasing the software and learning to do it yourself. You will save big $ in the end.
Old 12-02-2009, 08:58 AM
Registered User
Breth's Avatar
Yeah do it your self on the stock ecu, is a bit dangerous i think. I never did that before. Other thing is that the stock ecu cant`t reed boost right??
Old 12-02-2009, 09:08 AM
Registered User
Breth's Avatar
So a FMU will not work for 8-9 psi and 400-450hp?
Old 12-02-2009, 09:11 AM
lownslo's Avatar
well depending on the year of the truck you can use a 2 bar map with a cos and have a boost referenced table to read off of! There are many ways you can tune it but if you plan to just put a good tune in the truck and not change much i would def give blackbearperformanc(DC_Justin) or any other sponsor a call and look at your options!
Old 12-02-2009, 09:33 AM
Resident Retard
BlackGMC's Avatar
A stock ECU can read boost but you need a Custom OS (to tune it properly) and a 2-bar Map sensor, the which one of the sponsors i suggested above can provide the PCM and you can buy a 2-bar Map sensor...
Old 12-02-2009, 10:33 AM
Registered User
Breth's Avatar
Yeah i made a email to justin from blackbearperformance.... I will check what he can do...
Old 12-02-2009, 10:59 AM
trever1t's Avatar
Justin is great, the only difficulty I see is internation shipping is a PAIN IN THE @ZZ. But Justin can send you the hardware and from then on you communicate and make adjustments via email so that really is a viable option.
Old 12-02-2009, 11:26 AM
Registered User
Breth's Avatar
Yeah true...
I will see what he saying
Quick Reply: Whats the cheapest way to tune a turbo silverado?
