What would cause PCM fuse to blow?
I installed a new PCM (tuned by nelson) for a 3000 rpm stall. I disconnected the negative side of the battery, installed the pcm and reconnected the negative side of the battery. About 30 miles later/5 on and off key cycles, while driving, I hit a bump and the engine turned off, everything else still had power to it (head lights, dash lights, radio, etc)
I got out and checked over everything to find a blown PCM fuse. I replaced it and drove home without any problems (so far)
Looked at the schematic for the vehicle in your sig. Sure nuff, the pcm/b fuse does feed the fuel pump along with some other stuff. I have seen many stock pumps start to die and take out that fuse. happy hunting.
Wrecker 426
Sep 30, 2015 09:39 PM
Velocity1
Sep 22, 2015 01:32 PM
muncie21
Sep 7, 2015 09:55 PM
