What to do..
With stock injectors, my o2's were at 910-940mv range at 100%+ Inj duty cycle. Now with the 31 lbs, mv are 740-850 at 70% duty cycle. Only change in tuning was on injector flow rate table. Changed from 21.76 to 31 lbs per hour. I want to increase fuel mixture but not sure where to start. Only table I know of is PE modifier based on RPM. (AFR) Should I be adding fuel in other places?
