warning lights
Old Mar 27, 2006 | 06:58 PM
wakeboarder_10's Avatar
Default warning lights
my abs and brake warning lights started flickering on and off on me. anyone else had this happen?
Old Mar 27, 2006 | 08:18 PM
SSlow 4.8's Avatar
what tune? It usually has to do with gear swap... did you recently do this?
Old Mar 27, 2006 | 08:47 PM
dc_justin's Avatar
Hello Dave
And what do you do to work around this? I reporgrammed a friend's truck over the weekend and adjusted the speedo from the stock 29" tires to his 35s and now the lights have come on.
Old Mar 27, 2006 | 09:13 PM
no tune, just stock. gettin a dyno tune tommorow tho
Old Mar 27, 2006 | 09:47 PM
SSlow 4.8's Avatar
they will probably figure it out on the dyno.. but normally.. for those lights to come on it has to do with gear swaps.. have either of your cases had anything to do with that?
and dc_justin, if you just tuned for tire size, are you using hptuners? if so... sometimes when you do that thing where you center the tire size.. for instance 265/75/16 it'll calc the actual size and than the size it enters in automatically is a little off... try to get those two numbers close.. its hard to explain but if you PM me i might be able to help you more... but if its not hptuners than i cant really help you on that.
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
carid
Oct 28, 2015 08:24 AM
carid
Oct 1, 2015 09:22 AM
Lthompson
Sep 21, 2015 07:06 PM
